After Alternator replace Rear Airmatic not working - Front Fine
Today I replaced my 2000 S500's Alternator and the Battery is 1 week old. I also repaired my front left side airmatic line that was broken during repairs, I used the MB compression connector ($92 dealer price) but you could find one similar for $15 somewhere. The front of the car is stable at correct height right and left. For the first time i have problem with rear not rising. This is not a coincidence something occurred during my or the dealer repair efforts that caused this I believe.
The rear left is slightly higher than rear right - but neither is as high as they were two or 3 days ago. I have not driven the car for 3 days for repairs.
Is there a reset procedure for rear struts.
I have Stop Car To Low message.
4 days ago the dealership replaced a fuse and diagnosed my bad alternator.
I need help with prognosis.
My thoughts on what could be the problem. [edit add - If the pump fails does the air in the struts that are not leaking remain up? or if pump fails do all struts lower]
I could have damaged an airline / sensor that controls rear struts (where is it located?) I have a pdf diagram of the Airmatic system just would like some wise support before I go touching anything.
A fuse is blown - (What if any fuse causes the rear struts to not rise) - edit [I checked fuses 9 and 46 and both are good - Relay O is should be fine as the front struts.]
The pump is broken, however the front works fine. (I do hear the pump engaging. How does it get the air to rise and lower the car anyway, shouldn't I hear air going in and out)
Any support is greatly appreciated. I have a new job starting Monday and would like to arrive in great spirits.
Yesterday I hit a speed bump and never lifted after that i will like to no the cost of parts and labor.
Based on my research please check for air leakage from the airline or strut or at the pump location. The challenge is I have not found a DIY to demonstrate how to access the pump. I will let you know when I find it. Until then I believe to change the pump is in the $450 - $750 range if you do it yourself not sure for dealer to do work.
Stay positive as in I am positively pissed at my car that I have been working on for 2 months straight. Cheers.
