DIY W220 AMG Center Mesh Grille Replacement
Old Jul 3, 2014 | 01:17 PM
rob_fed's Avatar
W204 C300 2010
After loosing the center grille 2 times due to unforeseen road debris striking the front of my car, I decided to make my own center mesh grille. The first time the entire front bumper cover and AC condenser was replaced by insurance. The second time, a piece of metal that was kicked around on the freeway ultimately stuck the lower center of my front bumper. The center grille was then lost and I still have a gouge in the lower lip. At a cost of $300 for a '06 grille (early years are less expensive), I decided to try to make my own.
Goals:
  • Grille must be removable
  • No new holes need to be drilled (foam 2-sided tape, plastic L brackets and black oxide trim screws used) screws used only in the bracket
  • Totally reversable if I find a factory grille for a good price
Note: If you don't care to have the grille removable, you can just take the grille material and create rough cut behind the opening and fasten with epoxy and/or small screws.
1. Poster board and foam board for pattern forming:
2.
3. Pep boys grille material:
4.
5.
6. Cut with Super Sheers and tape as you go around the new shape:
7.
8. Grille cut out, trimmed with automotive door trim and painted with VHT epoxy paint:
9. HID fog lights behind the grille, made grille to be removable to access lights later:
10: Finished grille:
Old Jul 3, 2014 | 08:54 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Very nice job. Seems like the lower grills on these cars are designed to catch something. Most of the time it is very large insects.
