Airmatic problems continue
Old 10-27-2014, 11:07 PM
chrissclass's Avatar
S500 4matic
I have a 03 S500 4matic that is having some airmatic problems. All the struts are ok. Hoses and compressor all checked ok as well as the fuses. The problem was traced to a bad valve block. I replaced the block with a used one that tested good. Car did fine and is at correct height but the AIRMATIC VISIT WORKSHOP message has re appeared after driving the car for awhile but the car stays at level on all sides. I have read all the posts on the airmatic but am still baffled. Help
Christopher
Old 10-28-2014, 06:58 AM
tusabes's Avatar
Mercedes
If the car drives fine it might use need a reset , disconnect battery for over an hour
Old 10-28-2014, 10:04 AM
Quadcammer's Avatar
96 and 08 911 turbos
instead of guessing here, find someone with star and have the codes read.
Old 10-28-2014, 10:44 AM
wallyp's Avatar
2003 S500 2007 GL450
The computer monitors quite a few factors in the Airmatic system. This includes things like the time required for the pump to increase the pressure a specified amount, maximum pressure achieved, etc., etc.
As Quadcammer says, the next step is to have someone with DAS read the codes and run the system tests on the Airmatic system.
If the pump is weak, you can buy a replacement piston seal for about $25. Relatively easy installation, and will often restore pump effectiveness.
Old 10-28-2014, 10:57 AM
Quadcammer's Avatar
where did you get that piston seal wally?
thanks
Old 10-29-2014, 01:05 PM
wallyp's Avatar
Some info on the piston seal...
http://www.instructables.com/id/Wabc...n-Ring-Seal-R/
http://www.ebay.com/itm/WABCO-AIR-SU...-/151062196353
Pretty simple fix. While doing mine, I discovered that the air filter was missing, so I added an inline filter as well.
Quick Reply: Airmatic problems continue
