Grinding / Rubbing during sharp turns, reverse
Old Nov 11, 2014 | 03:46 PM
denversun28's Avatar
2005 S500 4matic
Just picked up a 2005 s500 4matic. Used to have a 2001 s500 and I missed the ride so I had to get back into a S-Class. Anyhow, been searching, see lots of threads, but nothing definitive.
Basically, when you turn hard, you feel a rubbing or grinding sound. Feels like it is coming from the rear. Interestingly, in a large abandoned parking lot I drove the car in reverse in tight circles (both left and right). After a few revolutions, the noise went away. Put the car in drive, tight turns seemed ok. Later that day - problem came back. I have seen the post for Mercedes 2007100004, but the reason I am posting this is that I have not seen a post any more recent than 2010 and I am wondering if there is anything else that this could be (other than transfer case). Bearings? I'm not super-mechanical, but do enough to be interested in what is causing this.
FWIW, I called my dealer about MSC 2007100004 and when I provided the VIN, the service manager said that the only recall is for a faulty instrument cluster that is covered in full by MB if it happens before 1/2015.
Did this MSC expire and is it possible that the dealer didn't tell me that? (I realize it makes no difference at this point).
Thanks.
Old Nov 11, 2014 | 04:34 PM
tusabes's Avatar
Mercedes
Do a transfer case and Differential fluid change and more figure 8s after the fluid change in the parking lot
See
https://mbworld.org/forums/s-class-w220/561928-transfer-case-differential-fluid.html
Old Nov 12, 2014 | 10:14 AM
wallyp's Avatar
2003 S500 2007 GL450
Second the suggestion for a fluid change, and would add that you should make certain that the fluid used is exactly that specified by Mercedes.
Old Nov 29, 2014 | 10:39 PM
2005 S500 4matic
No change
Replaced with OEM gear oil, problem not corrected.
Old Dec 8, 2014 | 08:28 PM
Conchasjim's Avatar
2016 GL350
Ditto on the transfer case fluid change. Worked for me!
