How to remove S430 stuck Water pump
Old Dec 7, 2014 | 12:05 AM
gary430's Avatar
2000 Mercedes S430
All the bolts are removed. But the water pump still stuck to the engine block. I am not able to pull it off. Is it supposed to come off easily ? Any special tools needed ?
Old Dec 7, 2014 | 01:20 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Perhaps try the W220 forum?
Old Dec 7, 2014 | 03:57 AM
cmpcpro's Avatar
2004 CLK 500
Sorry your looking for next door down the hall to the left. But if you have all the bolts off and you can't see anything else that could be holding it on then it may just be the gasket stuck.. Just don't stick a screw driver in there and start prying, don't want to mess the block up!
Old Dec 8, 2014 | 06:38 AM
G.AMG's Avatar
S500
A couple of light taps with a soft blow hammer should do the trick.
