radiator fan makes weird noise
I'm driving a 2001 S500.
I'm not sure if I'm getting spoiled, never realized it before or if it's getting worse, but for a week or so I realize a strange noise after I turn off my car. I opened the hood and had a friend turning off my Benz and the noise is coming from the radiator cooling fan. It's like a grinding noise. When I turn the fan by hand I can hear the noise again.
The fan shuts off with the car so it is not running afterwards. I'm living in New Mexico and the temperatures are in the 50s/60s at the moment (03/06/20150 so it is not really that warm yet.
I'm just wondering if there is something wrong with it or if it's normal to hear that noise and I just never realized it before.
If I have to change the radiator fan, does anyone have a clue how to do it or an DIY link?
Thank you for your help and have a great day,
Chris
After owning the W220, I am starting to change my mind about the superiority of engineering from sindelfingen. The W220 is built like a Tata or a mahindra when compared to the real thing the W140.
My W140's both 1999 S500 and S320 are keepers.
my advice. Don't mess with it. Take it to a reputable independent mercedes shop.
they have seen this problem many times before.
Some use a belt-driven fan.
Some use a direct drive fan.
Mine is direct drive.
I don't believe they're interchangeable.
Make sure the fan isn't rubbing against anything. Mine did (my fault) and it failed.
Nick
Search for this in Amazon:
Depo 340-55003-100 Radiator Fan Assembly
Easy to install, two bolts. There's a DIY on the site somewhere. Fixed my problem. Sounds like it's yours too.
