Cheapest and easiest way to add aux cable to 2003 S500?
Old Mar 6, 2015 | 01:31 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Helping another friend of mine out. He does have CH changer if that matters.
Old Mar 7, 2015 | 01:04 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
My 2003 has an aux cable input in the glove box. I think 2003 is the only year that came with this feature. If you look in your glove box on the left you will see where the aux cable goes. I use it for my Ipod. However, it does not allow you to use the steering wheel controls and it will not show what songs are playing in the command.
Old Mar 7, 2015 | 06:46 AM
Jason B's Avatar
Are you sure about this? We looked in the glove and saw nothing.
Old Mar 7, 2015 | 12:16 PM
Jason B's Avatar
Ok, we just checked his glovebox again, there is no headphone port.
Old Mar 7, 2015 | 12:47 PM
ibeforreal's Avatar
I thought it was standard on 2003 S-Class. Maybe it was an option but mine does have it.
Old Mar 7, 2015 | 12:57 PM
Jason B's Avatar
Thanks again, so I guess the question is, where do we go from here? There is a CD changer in the trunk. I hope that helps things.
Old Mar 7, 2015 | 01:26 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
It appears that John is correct. According to the Comand manual for the '03 model, the AUX connector was for hooking up mainly a tape player in the glove box. The years 00-02 then 04-06 had a built in tape player as part of the Comand unit. The 03 does not have a built in tape player.
See attached PDF pg.s 200 thru 202
Bob
(John, please verify)
File Type: pdf
Old Mar 7, 2015 | 02:52 PM
ibeforreal's Avatar
Bob, you are correct. My car does not have a tape deck. Truth be told, I never knew the plug was there until I was changing the filters under the glove box. Thought it was a screw until I realized it was for some type of connection. I decided to test it and realized it was live. Went to BestBuy, bought the cable you see and plugged in my IPOD. The IPOD works from the AUX menu in the Command unit.
Jason you might want to go into the "start here" section of the forum. There is a multitude of information on this subject and others related to the CD player/sound system.
This is how mine looks.
Attached Thumbnails Cheapest and easiest way to add aux cable to 2003 S500?-picture-aux-plug.jpg
Old Mar 7, 2015 | 04:09 PM
cybertronicify's Avatar
2003 S430, 2014 E350
Even though you have a 2003 S500, you might not have stock command. See if you can get the LCD screen to move down, it will reveal a tape slot. If so, you can get a tape to AUX adapter. I have an iPod cycling through my music, and it has a portable power bank attached to it, which is charged from the car. All self contained inside the glove box. Too bad I can't switch songs without reaching over and opening the glove box.
Old Mar 7, 2015 | 04:26 PM
Jason B's Avatar
Great idea! I just asked him and he said yes the screen moves down and has a cassette! I never knew it was there. We will try that. I know someone else that does that in an older Maxima and I thought it would sound like crap, like a tape mono sound, but no it sounds great.
