s600 misfire codes have power
car has check engine light on, owned for a week i can get over 60mph rpms like 1500 not high, owned car for a week before i start changing coil packs and plugs, modules, since i don't have a total power lost , could it be catalytic converter, flue / air,any suggestions before sending a lot of money car has 105k
Petrol (275.950 - MME 2.7.1 - MT/AT - 220.176/876)
DTC Description
P2033 - Comparison of the pressures between components (Pressure sensor upstream
of throttle valve), (Pressure sensor downstream of throttle valve) and sensor
'Ambient pressure' in control module (ME-SFI [ME] control unit)
- The ambient pressure is measured by a pressure sensor in control module
(Engine control unit)
- Intermittent
P2043 - Misfiring
- Permanent
P2044 - Misfiring cylinder 1
- Intermittent
P2046 - Misfiring cylinder 3
- Permanent
P2047 - Misfiring cylinder 6
- Intermittent
P204A - Misfiring cylinder 7
- Intermittent
P2003 - Secondary air injection, malfunction
- Intermittent
P2045 - Misfiring cylinder 5
- Intermittent
P204E - Misfiring of cylinder 9
- Permanent
P20F3 - Ignition module
- Left bank of cylinders
- Intermittent
DTC Description
- Intermittent
P2043 - Misfiring
- Permanent
- Intermittent
- Permanent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Permanent
- Intermittent
