Mike
Old Apr 24, 2015 | 02:10 PM
Conklin1's Avatar
2004 S430
Mike
radio say system unavailable Benz S430 2004
Comes on then when I'm driving it goes out sound only I know it's something to do with the fiber optics sounds like a short somewhere
Old Apr 26, 2015 | 12:14 PM
wallyp's Avatar
2003 S500 2007 GL450
I'm sorry if this is hurtful, but I have read your post repeatedly, and I don't understand it at all. Perhaps reposting with clear, concise sentences and much more and more precise detail would help us to understand your problem.
Old Apr 28, 2015 | 12:07 AM
jnash's Avatar
2017 S63
Lol. Yes, if the sound stops then you have an open circuit in your fiber cable caused by a break in the optics cable or more likely a component in the loop such as bad cd changer, cell module, or voice control if you have any of those options. U can bypass each one with a $8 adaptor from the dealer.
Old May 13, 2015 | 03:00 AM
Conklin1's Avatar
2004 S430
Conklin 1
amp and cd changer was bad radio nav cd all wking fine now
Old May 13, 2015 | 03:08 AM
Conklin1's Avatar
2004 S430
Mike
im having a lot of electrical problems with my 2004 S430 127k miles right now key won't work and SRS LIGHT ON STEADY KEY WILL NOT TURN IN IGNITION
Old May 13, 2015 | 03:09 AM
Conklin1's Avatar
2004 S430
Mike
wallyp u can't read man ???
Old May 13, 2015 | 05:26 AM
cybertronicify's Avatar
2003 S430, 2014 E350
Conklin1, not to be rude but I can barely understand some of the posts you have started on this part of the forum. Next time instead of writing "Mike" as the topic, try like "SRS LIGHT ON does not turn off" or something like that, so you will get a higher chance of getting more opinions from different people.
After all, your words are our eyes and ears to the problem. With a very broad description of the problem; we can't fully understand the problem.
Sorry if I offended you in anyway.
Old May 13, 2015 | 01:00 PM
tusabes's Avatar
Mercedes
It sounds like you have water damage , same things happened when my trunk got wet
