What is this plug under hood!?
Old May 28, 2015 | 08:03 PM
s500queen's Avatar
s500
I went under hood to check the check valves and saw that the blue valve wasn't even connected to the hose smh. After connecting it I noticed a plug chilling in between the valve hoses (see picture). I don't see aaaanywhere it could go. Any idea??
Old Apr 6, 2016 | 11:29 AM
engindin's Avatar
2002 S320L
sorry but I can't see anything blue, that plug may be for pressure sensor. Do you have check engine light on?
Your vacuum hoses are looking old, I bought around 2 meter from dealer and replaced them recently, it was simple and easy.
Old Apr 6, 2016 | 03:27 PM
wallyp's Avatar
2003 S500 2007 GL450
I just took a quick look at my 2003 S430 - If you look down and to the right on the photo, there is a connector just under the small hose. The only other connectors I saw were for the closest fuel injector, and (if the connector has a very long harness attached) the AC compressor down at the bottom.
