S430 listing to one side
My 05 s430 4matic is listing (pass side low). This came after I replaced the following: front struts, lower control arms, upper control arms, stabilizer links and front axles. Car was level and fine before I replaced the parts, but all the squeaks, rattles and rolls are gone. Now, however it leans to one side. I know I had to have fudged up the ride height on the sensors, but can't for the life of me, figure out how to simply reset the height. I have even placed a jack under the offending side, disconnected the battery and let the car sit for a while, and reattached the cable and alas, no resetting of the ride height. (Stop laughing). I have even read about the washers method. And I will gladly take the car to the dealer/Indy to have them reset the height. But, I was simply hoping that I can fix whatever idiot thing I did to alter it, by myself. I put it to you fine members, please tell me the simple 27 step process, done on specific day of the week that solves my problem.. ; ). You guys rock...
Presuming that's where it should be, drive the car around for a few minutes and it should recalibrate itself and level out.
I checked this morning and the fronts are sitting even. I measured from the top of the rim to the fender and the fronts were at 18cm. The driver rear was at 16cm and the passenger rear was just a bit below 15cm. You may be right about the slow leak. A few days ago I heard the airmatic pump turn on late at night (car had been parked for several hours).
What I can't figure out is if there was a leak the pump should try to get the car back to the same level as the other side and it would be running constantly. Instead I have only heard it run once, after shutting down, and the car is consistently at 15cm. Is there that large of a range that suspension height can be in before the pump turns on?
The car doesn't drop overnight and stays level when running. My mechanic didn't find any fault codes. According to him it's normal for the car to have .5 inch of difference between the heights. He also said if the ride height went out if spec I would get a notification on the dashboard. For now I plan to keep an eye on it and measure periodically to make sure it stays consistent. If I have time I'll take some measurements with the car running, lifted up and off to see the difference.
Hope somebody can share some idea to my 03 W220 S280 problem # Currently experiencing loud rubbery squeaky Fr LHS suspension when ride on uneven road surface prominently speed breaker (humps), especially my housing area has more than 21 of them. The squeaky noise very recently appears consequently after few occurrences both front airmatic lowered (sometime) when park overnight. Could it be the inner airmatic strut that create the noise. ????
# both front airmatic was newly replaced about 12mths ago.
Dry ball-joints can squeak. Sometimes, you can help this by buying a sharp needle that snaps into a grease-gun and injecting grease into the rubber boots. Here in the USA, the needles and several different styles/sizes of grease-guns are available at any auto parts store.
Appreciate greatly your kind respond to my squeaky airmatic front suuspension. Will take your advice on ball joint greasing and sway bar bush replacement soon. Further, out of curiosity , is there any chance the airmatic strut within itself is the culprit.
Sometimes true. Sometimes, repeating the injection a couple of times will last for quite a while. I'm willing to try the process a couple of times if the rubber boots are in good condition. Easy to do, costs virtually nothing. Well-lubricated ball joints will last a long time...
