S430 listing to one side
Old 10-01-2018, 12:39 AM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
Here's a thread on the w221 creaking suspension sound most noticeable when going over speed bumps:
https://mbworld.org/forums/s-class-w...replacing.html
Click on the PDF for instructions with photos.
Worked like a charm on my S550!
Old 11-17-2018, 11:37 AM
ltinto's Avatar
s500
air sus problems
Originally Posted by Mike5215
I'm guessing you reconnected the link between the upper arm and the ride height sensor, and that the sensor is still connected to its harness.
Presuming that's where it should be, drive the car around for a few minutes and it should recalibrate itself and level out.
Adjusting the front is simple. There is a tiny rod near the front strut this controls front height right and left. You can buy these turnbuckles to adjust side to side in the front.
The rear has one adjustment that controls both this adjuster is above the rear differential. You can adjust this with shims but it doesnt allow for Right left adjustment just up/down
Any creaking in the front are ball joints, replace them and itll be okay.
Good luck
Old 11-17-2018, 11:40 AM
ltinto's Avatar
s500
The pump releases air when parking to protect the air struts, this is normal usually can go down up to an inch.
Quick Reply: S430 listing to one side
