Need ignition coil replacement
Old Sep 9, 2015 | 08:55 AM
bigmyself's Avatar
2005 S55 AMG, 2005 S500
Hi, all.
I am new to this forum.
I have 2005 S500 base model and 96,000 miles on it. I decided to replace spark plugs and wire set and ordered. ( Bosch 9652 iridium plugs and Bosch 09850 premium spark plugs wire set).
Do i have to replace ignition coils together?
How often does it have to be replace?
Thanks for reading.
Old Sep 9, 2015 | 08:26 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Any particular reason why you want to replace your ignition coils? I have never replaced mine with over 100k miles on the car.
Old Sep 9, 2015 | 08:57 PM
tusabes's Avatar
Mercedes
You posted this same question here and at benzworld
The answer is the same - no need to change coil unless there's a problem . You already said at benzworld you have no problem
Old Sep 9, 2015 | 10:25 PM
bigmyself's Avatar
I do not think I have any problem yet.
I didn't know when I need to replace ignition coils. Like said above, I am going to replace spark plugs and wire sets next week myself and want to replace coil packs together if it is time to do cause mine car is getting close to 100K miles.
Thanks for reading and replying to my post.
Old Sep 10, 2015 | 05:28 PM
ibeforreal's Avatar
Those ignition coils will let you know when there is a problem. There are 8 of them and they are not cheap. When you replace the spark plug wires just put a small dab of the dielectric grease inside each wire. Helps the seating of the wires on the plug. It also helps if you have the special 17mm wrench. DO NOT put the grease on the plug threads.
Old Sep 10, 2015 | 05:58 PM
bigmyself's Avatar
John.
Thanks for your reply and kind advice.
I already ordered 'Mercedes Benz V6/V8 Spark Plug Wire Remover Installer Wrench Tool 17mm' from Amazon after reading this forum.
Is it hard to connect a wire to a plug without dielectric grease?
Old Sep 10, 2015 | 06:25 PM
ibeforreal's Avatar
It's not that difficult without the dielectric grease. However, it certainly helps if you have to remove the wires in the event of a misfire or something. Whatever method you choose just make sure when the wires are inserted just push them down until you hear a click.
Incidentally, the dielectric grease if really inexpensive and you don't need one of those big tubes.
Old Sep 10, 2015 | 07:24 PM
bigmyself's Avatar
John,
Thanks again!
I ordered one tube of dielectric grease from amazon.
Your advice give me more confidence to perform my first plug replacement.
