Gearbox oil
Old Nov 28, 2015 | 09:43 AM
salmanabdulla's Avatar
S500
Gearbox oil
Hello every one
i have Mercedes benz model S500 / 2001
how i can check oil level and how i can change ?
and which oil types good ?
kindle help me please
Regards
Salman
Old Nov 28, 2015 | 09:53 AM
wallyp's Avatar
2003 S500 2007 GL450
The only way to check the transmission fluid level is to buy the dipstick tool. In the USA, eBay is the easiest and cheapest source. Correct fluid level in the transmission is very important.
Different brands and types of fluid are sold in different parts of the world. Mercedes has lists of specified fluids.
You will find a lot of information here:
http://www.benzworld.org/forums/w220...l#post10079385
It is easier to get the correct help if you tell us where you are...
Old Nov 28, 2015 | 05:55 PM
Welwynnick's Avatar
2006 S600
Use MB 236.14 which is commonly known as ATF 134 or ATF 4134.
MB 236.12 or 236.10 will also work, but the latest types are recommended.
Getting the level right is important, and exacting.
The level is measured with the car on level ground with the engine running and the transmission in neutral. You break off the locking tab to remove the dipstick tube cap, then fit a new one.
Ideally the transmission should be at operating temperature - 80 deg. C. This is only achieved after driving fast for 10 to 20 miles.
The fluid level varies considerably according to oil temp (about 0.8mm per deg. C), and there's a second mark on the dipstick for ambient temp level measurement (20 deg. C).
The dipstick tool is long, and has to wind round lots of bends to reach the tranny sump. When it hits the bottom, it will still have several inches sticking out the top.
Keep the dipstick spotlessly clean at all times.
Nick
