Squeaky brakes.
EDIT: The brakes actually squeal when cold, when I heat them up after a freeway off ramp. It doesn't squeak when I come to a complete stop, but squeaks again the next time I brake.
So, I suspect it's the new pads running on the deposits of the old pads...This might clear up with time. Or it might not. IF you want to be certain, and fix it now, get the rotors turned, just a tiny bit, be certain that your calipers are clean and the antisqueal paste/stuff again between caliper pistons and pads.
What I do in the Audi is I slam on the breaks hard a few times to get the breaks wormed up. it's the cold medal that is the problem. Try breaking late, on stop signs or red lights with no one in front of you. The Audi drives me insane though when It does this. and thats almost every morning, with me slamming on them at every given point.
The Benz also stops the squeaking when I slam on them once or twice.
But the OP was talking about rear rotors...
Either way, the European cars that I've owned (and it's been quite a few) are very prone to squeal. They also don't respond well to a "pad slap" in which just the pads are replaced without resurfacing the rotors.
So, you can try another application of anti-squeal paste on the critical spots. When that fails, try resurfacing the rotors and bedding the pads...
After I let everything dry. I lightly sanded both pads, if I were to guess, 0.005 inch off the pads. I cleaned the pads off again with some simple green and proceed to put the red anti squeal everywhere. Behind the pads on the anti squeak backing plate. Caliper contact points, on the ears, on the piston where it contacts the pads.
I even put the included brembo grease on the caliper guide pins for good measure.
Today I did a test, I let someone drive super slow, 1 mph in first gear on the brakes. They were squeaking loud and clear. I sprayed some water on the calipers, still squeaking... Then I poured water all over the rotors and BAM. No more squealing. (At least until I took it out for a drive and let the water evaporate...)
I'm out of ideas, i'm going to call Autohauaz tomorrow to see if I get get their Bosch Quietcast as a replacement for my Brembos. It has to be quiet since it has the word in the name. It says OE compound.
http://www.autohausaz.com/search/pro...ke%20Pad%20Set
But water on the rotors made it quiet...and you still don't think it's related to the rotors?
Could it hurt to try what I've been telling you?
Do you guys recommend the Liqui Moly engine flush? I have the same lifter ticking noise that my friend with the M113 E50 fixed with the flush. Would it do any damage? I'm in need for an oil change anyways.
I'll update when I get them replaced.
