Shifting issue
Old Apr 30, 2016 | 08:03 PM
Slimm82's Avatar
W220
Shifting issue
I need help. I can't find a definite answer. 2000 S500. When I start the car, the current gear (PRND) does not show in the dash. Where the current gear should be is blank. Only the clock is there. When I put it in D, naturally, it wont go back into park unless I turn the car off. Seems as if theres a disconnect between the shifer and the computer. In addition, when shes in gear and being driven, shes stuck in what I believe is either 1st or 2nd gear. What could be the problem? I've read the connector on the valve body or the gear shifter itself. Where should I start? I haven't ripped anything apaet yet as I am still researching the problem. I need to fix this so I can sell this car. Thanx in advance.
Old May 1, 2016 | 10:32 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
if you read and search the forums, you'll most likely find your answer in "trans oil wicked up to control unit".
Good luck!
Old May 1, 2016 | 10:34 PM
Slimm82's Avatar
W220
Good luck!
I saw that post. It wasn't helpful in this case. I'll go over it again. I was pretty pissed when I read it the first time.
Old May 2, 2016 | 07:20 AM
tusabes's Avatar
Mercedes
Here's the video on how to replace the electrical connector that allows the fluid to damage other parts causing shift issues
Originally Posted by tusabes
How to change transmission electrical plug
(Fluid leaks into wiring)
Mercedes transmission 722.6 electronic connector leak - YouTube
Old May 2, 2016 | 07:37 AM
Slimm82's Avatar
W220
Yep. Saw that during research. Checked it yesterday. No fluid in the area. Thanx tho.
