Pre-Safe Unavailable 2006 S500
Old Jun 21, 2016 | 04:10 PM
Gary Krboyan's Avatar
2006 S500
Hi. Does anyone know how to reset the "pre-safe unavailable" message? It comes on every time I start the car , and the only way I can temporarily clear it is by pressing the R knob next to the odometer.
Old Jun 21, 2016 | 04:13 PM
Jack_88's Avatar
2018 C300
If it comes on everytime, it sounds like the system has a problem. Or at least the car thinks it does. Have anything fixed recently?
Old Jun 21, 2016 | 04:21 PM
2006 S500
Car was repaired after front collision. I tried to get it reset at a local brake shop, but their systems didn't show any malfunctions. Is there a reset I can do without taking it to the dealership?
Old Jun 21, 2016 | 04:41 PM
Jack_88's Avatar
2018 C300
I would suspect some sensor is out of calibration and needs to be recalibrated. I don't know enough about Mercedes to go into any detail, but that's almost certainly the source of your problem. The repair was never truly completed.
Old Jun 22, 2016 | 02:00 AM
MikeKerr7's Avatar
S-series 2003 S500 4matic
You likely have a issue along the lines of a discharged seat belt safety charge from the accident. MB believes pulling back the seat belt when an accident occurs is a better safety feature than an airbag.
To pull back the seat back in a millisecond it takes a "explosion" in the seat belt box. This is a one time explosion and requires internal repair and/ or replacement of the entire seat belt assembly.
Only a STAR system will point you to which seat belt(s) have be discharged.
If you are in the central PA area, feel free to come by and I can plug in the STAR and help you diagnose.
Old Jun 22, 2016 | 09:17 PM
tusabes's Avatar
Mercedes
It's your seat belts
They must be replaced after collision
