Airmatic visit workshop C1322 - Right front solenoid
Old Jul 6, 2016 | 11:47 AM
Borota's Avatar
Mercedes S500 4Matic
(Please excuse my english,i'm from Transilvani -Dracula's land )
Hello,i have a problem on my car (MB S500 4Matic W220 facelit)i have a malfunction on the dash "Airmatic visit workshop" and on the tester appear: C1322 - Right front solenoid valve 1
- Permanent
First of all what this error means,because i couldn't see anything wrong with the car,the car lower itself when ii stop the engine,but never to low,only to aline itself,even if i park the car for 3-4 days the car never lower it self more than it should be.When i start the engine the car lift itself as normal.So i'm sure the struts doesn't have any leak.
And secound what can i do to fix this problem myself,i search for exact this problem C1322 and i couldn't find any solution how to fix it.
This is my first MB and i have it for 1 mounth.
Please help a friend in need
Update: after 3 days of not starting the car,i just realize that the front left side of the car is very easy to push it down and up,it easy to balance the car but the front right side is very stift,i cannot push the car down,and the front right side is higher than the left side with 0.5 inch.
Old Jul 6, 2016 | 01:35 PM
Borota's Avatar
Old Jul 7, 2016 | 12:55 AM
Borota's Avatar
I found this in a W220 Encyclopedia.Maybe i need to replace y1-front axle solenoid valve 1.It this possible,to replace it,is anyone who has replace this?
Design
Y51 - left front axle damping valve
y1 - front axle solenoid valve 1
y2 - front axle solenoid valve 2
p - piston reed valve pack
Old Jul 7, 2016 | 09:25 AM
wallyp's Avatar
2003 S500 2007 GL450
As you found C1322 indicates that the valve inside the strut (damper) is reporting a problem.
First, carefully check the electrical connector from the strut that plugs into the body in front of the strut. It is not unusual for that connector to be inserted wrong.
If there is no problem with the wiring or connectors, you may have to replace the strut, as the valve is not available separately.
