s430 chain guide tensioner replacement
One guide can be replaced without removing timing cover and cylinder heads. the rest need major disassembly work. Most likely the chain is stretched. You can do the chain, cam gears, the one rail, and new tensioner and you should be good to go. I've never had to replace the other guides to rid that noise
