MAF HELL. PLEASE HELP!!
Old Apr 19, 2017 | 12:54 AM
  #101
tusabes's Avatar
Mercedes
Originally Posted by CLK500 TWINS
Just popping in to check on you Amstel, how did you make out? I'm happy to report the S55 is still running strong.
awesome , what was the final solution to fixing your issue ?
Old Apr 19, 2017 | 01:06 AM
  #102
CLK500 TWINS's Avatar
2001 S55 AMG Silver, 2003 CL600 Black Opal Metalic, 2005 CLK500 Silver (sold)& Orion Blue (sold)
MAF, Vacuum leaks - many hoses, Intake manifold gaskets, Missing MAP Sensor- All caused poor running conditions, various headaches, poor power and CEL (Too rich at idle -->(then) MAF circuit a). These rich running conditions killed Cats, replaced both the fronts with Magnaflow, cut out and straight piped the rears.
Old Apr 19, 2017 | 09:10 AM
  #103
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Just popping in to check on you guys, Amstel how did you make out? I'm happy to report the S55 is still running strong.
Glad to hear your car is still running well! As for me, I've been working on fixing my dreaded P0410 secondary air injection issues. I recently cleaned out the check valves and replaced the switchover solenoid (Y32). Hoping that solves my problem.
Additionally, I have to check my rear A/C system as the air coming out of the vents in the center console for the backseat is warm. It's not hot, nor is it cold. I'm thinking after 11 years, the system could probably use a refrigerant top up.
Apart from that, the S65 has been running well. Drove it to Washington D.C. a few weeks ago and didn't have any problems.
Old Apr 27, 2019 | 07:34 AM
  #104
johnathan1's Avatar
2001 ML320, 1998 E430
I have to say this thread was quite the read! In the first pictures of the disconnected wires, those orange-banded plugs plug into the coil packs... surprised that nobody else seemed to really notice or say anything. Glad to read your car is running great !
