MAF HELL. PLEASE HELP!!
Did you decide to replace the cats anyway? I know you said you already ordered and received them right?
I unfortunately still haven't ordered my MBII, so I looked for what was available in local parts stores, so that I could do the live readings on my 02 sensors & fuel trim, check all cylinders (even though the misfire monitors are ready, so I was almost certain it wasn't a plug or coil issue).
The scan tools that are readily available and capable of doing what I wanted were $200+ and weren't as comprehensive as I believe the MBII ($150) is for these cars. I needed to know for certain though as yesterday and today are the only days out of the week that I can be without the car. So I bit the bullet and took it to Mercedes (a different one as I've hated the first two) early this morning for confirmation.
They did all the required testing and the foreman spoke with me about all the results, my 02 sensors are not original, and are operating correctly/ no adaptive issues- fuel trims are good, pressure/map (is there
) and functioning correctly, maf functioning correctly. Only thing left is the cats, they said they were 200% positive and that confirmation based on actual diagnosis and not just code reading was all I needed. They at least were a decent dealership, I rather liked them a lot better than either of the two I had already been to. They didn't try to sell me on factory or convince me aftermarkets wouldn't work. The foreman actually offered to put them on if they were bolt on applications. I took it directly to the exhaust shop and left it, they are being done as we speak. Let's hope after this I can actually enjoy the car for a while. I hadn't even gotten to the little cosmetic things I want to do, it's been one thing after the next and both me and my wallet are quite tired.
02 sensors, replace them because cats are being replaced or leave them alone if they are still doing their job correctly? Spark plugs and a regular tune will be in my immediate future -iridium or regular platinum?
Got my fingers crossed for you. Hope that once the exhaust shop installs the new cats, you'll be trouble free (for at least a while). I can completely sympathize with you and your wallet. I'm going to have to replace the engine mounts in my car soon, along with front torque arms, and lower control arms due to worn out ball joints.
Having the V12 biturbo, but never having driven an AMG- I didn't believe I was seeing any loss in power. The car had a decent kick, or so I thought. As my guy thoughtfully pointed out though, I bought it running like sh*t, so what could I compare it to
. After picking it up this afternoon, I can see just how much the engine was suffocating during the last week and how thankful it seems to be able to breathe again. This thing has serious power, to the point where I believe I will have to relearn the car - hell, the car may have to relearn itself. What a difference, really. Rear cats are gone entirely, it only sightly roars above what I believe factory would, but oh boy does it move. Throttle response is flawless. It has been a long and expensive journey bringing her back to life, but driving it now makes it feel like it's been worth it. The exhaust guy said he tried to clear the code like 3 times but it wouldn't go out. When I started her up, it went out on its own (good sign). Fingers crossed that it will hold steady, I will come back and update the thread either way.
As always, the help I received here is/was massively appreciated and invaluable in most instances.
I did see you on the AMG forums, the price we pay to love these cars right. I will likely go with the regular Bosch platinum once I have had a chance to recover from this month. I had really good luck on FCP Euro and you can't beat their lifetime replacement policy. Anytime it goes, you get new ones, period. I didn't find the torque arms you mentioned and it looks like those two control arms will set you back a bit. Mounts are very reasonable, the Mercedes brand version is $90-something.
https://www.fcpeuro.com/products/mer...oem-w215lcakt1
https://www.fcpeuro.com/products/mer...unt-2202400917
I'll speak with you soon, hopefully with nothing but good news to share
your v12 biturbo should be quite a bit faster then this Amg s55 though - this is the earlier non supercharged Amg with about 350 horses , your biturbo 600 should be making nearly 500
As for the torque arms, they're sometimes also referred to as thrust arms. They attach to the front knuckle. The lower control arms also attach to the knuckle but also serve as the lower attachment point for the ABC strut. Replacing both is fairly straightforward.
But I digress. Your car should be breathing a lot better now. Glad to hear that everything again seems to be working well. Come back to us in a few days with updates. Hopefully no more codes will appear.
Thank you though, I hope so as well.
If you can do the job yourself, all the better for you and your pockets. Maybe you can check out Victor and come back to us with your experience. He seems to pick repairing original parts over replacing them. Not saying your parts can be repaired, especially the mounts, but I'd love to see what he's capable of.
Yes, I will certainly update in some time and fingers crossed the cel stays off and codes remain at 0.
If I do end up having type B mounting arms, then I'll try to tackle this next winter when the car is garaged. If it's type A, then I don't know... WIS states the entire engine has to come out to replace the mounts. Others here have had luck dropping the subframe but even then, it's still an enormous pain to do.
The s600 in stock tune is very tame unless you get a aftermarket tune or are heavy on the pedal . The turbo feels faster when at large throttle , and as the speed climbs much faster without letting up
I have a 500 and biturbo s600- the 500 feels more responsive at light throttle , but upon heavy throttle the 600 just keeps pulling hard where the 500 can't quite pull away as hard
I hope for your sake it's type B. You could continue to shop around the indy circuit if it is infact A, but sometimes you get what you pay for and you don't want just anyone in charge of lifting your approx $50k engine out of your car and then the supercharger to boot. Any mistakes could cost you way more than the original 2k. Fingers crossed that it's B and you can do it yourself.
I solved my leaking transmission issue; damn thing was just overfilled. I took enough out that the fluid was right between the 80 degree hash marks when hot. No more leaks.
Secondly, I was in the process of replacing my transmission mount when after removing the old mount, realized that the one I got from FCP Euro was the wrong one. It bolted to the transmission just fine, but when I lowered it onto the crossmember, only then saw that I was missing a bolt hole. I couldn't bolt it to the cross member. Removed it, put the old one back for now.
I also replaced a torn up rear passenger control arm cover. PO must have driven over something that just chewed it up. Fortunately the control arm itself was OK.
Finally, I got the three front belly pans back on after all the mounting hardware finally arrived from ECS.
At this point, only thing left to do is sort out my continuing P0410 error code (secondary air injection pump). The pump itself works. I can hear it turning on when first starting the car when the engine is cold. I thought i might have pinched or cracked a vacuum line when reinstalling the passenger side coil pack, so I replaced the vacuum line going into the secondary air injection vacuum solenoid. That didn't solve it. So, probably will replace the solenoid soon to see if that helps.
There is light at the end of the tunnel. Just hope I don't run out of money before that happens.
You can also apply vacuum to the vacuum-operated valves to check the diaphragms.
I'm sorry to hear about the situation with the mount, were you able to get in touch with someone and get it remedied or is there something I can do to help out on that one--Kyle
Edit: just called FCP Euro. I gotta say, these guys rock. Talk about awesome customer service. I really appreciate your help Kyle.
You may have come across this already, but I did a quick search for you. It's the least I could do after the help you gave me.
The obd2 system checks it periodically for proper function.
Check vac lines to it.Disconnect the feed lines to the exhaust and spray with crc cleaner, check the check valve. It is not a circuit malfunction or anything that a fuel additive will repair.
In colder months the check valve will fill with moisture,The weather has warmed up and the code is gone,it will return when the weather gets cold.Cheap part,replace it before it damages the air pump,which ain't so cheap.
I'm happy to report that the S55 is holding up well with all of its new parts and I don't anticipate any immediate headaches. I'll continue to check back in and see how your issues are coming along.
As for the "Italian tune-up", lol... it's basically a few passes at WOT (wide open throttle) to blow out any carbon build up in the engine. Granted, it's a bit difficult to do in an S65 on public roadways. I added some Techron to the tank to help clean out the fuel system. May add a bit of seafoam as well later to the crank right before I change the oil in two weeks.
I'll solve this issue eventually.
