airmatic question
Old Mar 27, 2017 | 03:37 PM
hemi3275's Avatar
s430 2000 model, 2000 s600
Exclamation airmatic question
S430 2000 model, car bought at auction no key so I replaced eis module,ecm,shifter , right side sam,all with another s430 parts from know good car. Car was flat on ground jacked up rear...left on stands jacked up front slighly, display shows airmatic car rising... relay for compressor no +12volt for coil on relay.. has +12 on contacts... If I close contacts pump runs but no movement in suspension... Car does run and drive... no other problems.. I cant seem to understand even if I manually push switch on dash for airmatic raise up still no power to relay coil!!!
Old Mar 27, 2017 | 10:33 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W220 forum...
