MBTech208..2001 S600 rough idle
Any ideas??
Also, don't know if it's related, I get bad vibration from 78 to 81 mph.....in my seat and the empty passenger headrest almost shakes out of the seat. Just put new tires on and still happens....had them on-car high-speed balanced to 140mph......this also happens on all road surface conditions.
Thanks in advance for your help.
I've taken my car in twice because at idle (in park or D) and (AC on or off) car shakes or wiggles. Atlanta Classic say they can't find anything......but for the first 18k this engine was as smooth as a turbine!
Any ideas??
Sounds like a bad MAF (Mass Air Flow Sensor) may be the culprit. Has your dealer tested the MAF ?
Also, have you tried other brands of fuel ? I had a similar rough idle problem that was very inconsistant. Only happened at idle every once in a while. I Changed brands of fuel and it went away.
