Remote trunk opening pump fixed for free
Old May 15, 2017 | 07:34 PM
E42AMG???'s Avatar
E420
So my automatic trunk opening stopped functioning. I checked the fuses 13, 59, 62 all good and had power. Then checked for power at the pump plug, that was good.
Checked the pump for continuity and had nothing. So I decided to take it apart to see if there was a broken solder joint, and test continuity on the circuit board to see where the failure was.
I had no continuity where the power and ground wires connect to the circuit board then after testing everything it all checked out and I had continuity back at the power and ground wire I could not see anything that was loose but I put it back together and it works again.
If your pump goes out try taking it apart it took me 5 minutes and works great now.
Old May 3, 2021 | 04:17 AM
BayArchitect's Avatar
2002 CL600
Removed.
Last edited by BayArchitect; Jun 17, 2021 at 07:18 AM. Reason: Posted to incorrect thread...
Old May 3, 2021 | 11:36 AM
tusabes's Avatar
Mercedes
Originally Posted by BayArchitect
My 2002 CL600 deck lid has never closed properly. Pump compartment filled with water & shorted the motor. Passenger side front corner of lid never aligns with the body. Lid is difficult to open and close. Your article inspired me to go on eBay & order spring hinges today. Found a pair in my color--silver. $110. I could have purchased new from MBZ for about $280. I'm eager to get the parts and install them.
Good on you, 8 years on, and you're still influencing powerful men . Do you still drive the CL? Are you still happy with your adjustments? Any hindsite tips for me?
THANKS!
are you sure you’re talking about the right post ? This one is only 4 years old and deals with the pump not the hinges
also the spring hinges are not for the cars with the hydraulic power trunk lid closer . The cars with the power trunk lid closed only use gas struts and no springs
the trunk not closing at the corner is a common problem on cars with the power trunk closer
https://www.edmunds.com/mercedes-ben...trunk-lid.html
Old May 3, 2021 | 11:40 AM
tusabes's Avatar
Mercedes
Here are the two styles , the style with the spring is for the cars without the power trunk closer
Old May 3, 2021 | 03:19 PM
wallyp's Avatar
2003 S500 2007 GL450
Sometimes, a thorough application of a good penetrating lubricant will take care of hinge problems. Something like Kroil is best - WD-40 is NOT a good lubricant.
