s320 w220 boosted with 24volts
Old Jun 10, 2017 | 06:02 AM
PraveenM's Avatar
s320
Hi
In error the vehicle was boosted using 24 volts. There is no dash lights only SRS lights. Most of the fuses checked are working ie Right Back seat, engine compartment left and right fuse boxes. Is there any other fuse boxes?
Any assistance will be appreciated.
Regards
Old Jun 10, 2017 | 09:25 AM
wallyp's Avatar
2003 S500 2007 GL450
Fuse locations vary with model year, and perhaps with delivery area.
There are often one or more main fuses behind the trunk lining near the battery, and under the covers under the passenger floor carpet. These are the usual suspects.
Some models have a fuse cluster under a well-hidden snap-out cover on the end of the dash - open the door for access.
Old Jun 11, 2017 | 12:25 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
The fuses for the dash are located in the fuse boxes on passenger side. Just open the door and use a small screw driver to pry off the little cover at the end of the dash. There are fuses in there for things like the instrument cluster, cigarette lighters and the like.
Old Jun 11, 2017 | 02:18 AM
tusabes's Avatar
Mercedes
Originally Posted by PraveenM
Hi
Regards
most likely the main fuse blew under passenger carpet
see here
https://youtu.be/Jb_7E-Z5D7g
