DRAINING BATTERY
DRAINING BATTERY
Have noticed many noises (electrical things) happening in the car when the key removed. The navigation cd sounds like its continually running in the command unit. then in about 24 hours the car will need a jump start. Will replacing the radio (control unit) fix this issue, or does the computer need to be reprogrammed???
as a workaround you. Can get a $49 "remote battery disconnect" on Amazon so you just click a button and it cuts off battery power to prevent draining
