Another ABC question
I got clear fluid to come out the return hose into my bucket, so I stopped. I tried the Rodeo some more, and it was the same. When I set it to auto level, all went to a normal ride height and looked good. The system said ~175 Bar for pressure.
I am getting ready to drive ~2500 miles in the next couple of days, so I am slightly concerned. It gave a pump failure code also, seems strange with the pressure stated, and no significant leaks.
I plan to replace the hose and strut tonight, but if just one side is weak, could that be the rear valve block or accumulator? It has a significant hum to it back there too.
Any thoughts would be great.
Still have the low lift on the rodeo on the left side compared to the right. But sets just right when reset, and driving around. Fluid is full, and clean. I am getting yet another filter tomorrow, and I will probably change it out again.
Any ideas would still be great. I think the hang up on the rodeo is the left side causing problems.
Thanks for the thoughts, I think you are right.
Sooooo, if you can rodeo, I think you will be able to avoid the bleeder screw technique.
