Transmission issue detected
Old Oct 29, 2017 | 04:37 PM
redaotrosh's Avatar
W220 S320 99, W212 E350 2014
Hello, my w220 S320 had an issue since I bought it from 1 year, while driving sometimes during drive and use brakes then accelerate the car shift down from 3 gear to 2 gear and I feel the car is shocking as like some body hit me I dont know how to explain this feeling, specially after cold start but not always else I Scan it but no codes detected and I did reset transmission it gone for while then get it back, but while driving as manual no issues at all.
I didnt try to change transmission oil since I called Mercedes exclusive dealer he told me if it is from long time that oil didn't change it may ruins the transmission at all and you will be responsible for that. So I will not do it at all.
Old Oct 30, 2017 | 06:59 AM
tusabes's Avatar
Mercedes
You need to change the fluid filter conductor plate and electrical connector
you can get the parts for about $65 in eBay
just look for w220 conductor plate
Old Oct 30, 2017 | 11:44 AM
redaotrosh's Avatar
Thanks a lot and hope that will fix.
Old Nov 7, 2017 | 02:05 AM
Das Geld 2's Avatar
SL55, S500
thats cheap, I got OEM from ECS for about $150 last year.
Old Nov 7, 2017 | 06:57 AM
redaotrosh's Avatar
I found that there was a leak since spot of fluid on the ground may this related to low fluid while I get limp mode once per two months.
How much litres transmission need?
