Washer fluid leak
Old Jan 1, 2018 | 09:07 AM
Outrigger's Avatar
2000 S500
Washer fluid leak
2000 S500. Washer fluid tank is new, holds fluid, replaced all grommets, washer pump runs but fluid comes out on the windscreen half-heartedly. But as soon as I test it the tank then is totally empty. I will check the line for any leaks but not sure how that would empty the entire reservoir.
Old Jan 1, 2018 | 09:55 AM
wallyp's Avatar
2003 S500 2007 GL450
Sounds as if the leaking line sets up a siphon.
Old Jan 1, 2018 | 12:12 PM
Welwynnick's Avatar
2006 S600
have a look at the pipes in the plastic air intake plenum on the back of the hood.
Nick
Old Jul 22, 2025 | 08:19 PM
Andrear29's Avatar
2013 Mercedes Ml350
Can the windshield washer fluid leak into headlamp housing because my drivers side light assembly stays wet and lights keep going out.
