s class inside door opening handle - whats the small metal pin?
Old May 13, 2004 | 11:21 PM
mblover455's Avatar
does anyone know what the small metal pin is just above the door handles on the inside of each door?
i pushed one in and now it wont come back out.
any help here?
Old May 13, 2004 | 11:28 PM
awiner's Avatar
2003 CL55 AMG
It's a small light that lights the handle area. Only way to retrieve it will be to take the door panel off.
Old May 13, 2004 | 11:42 PM
mblover455's Avatar
do you know how and what
what panel do i remove? any help in doing this?
Old May 14, 2004 | 02:23 AM
Kar don's Avatar
Mercedes-Benz
Re: s class inside door opening handle - whats the small metal pin?
any help here?
the dealer might fix it for you if you are under warranty.
Old May 18, 2004 | 09:15 PM
mblover455's Avatar
INSTRUCTIONS ON OPENING DOOR PANELS IN S500
first remove the wood by using a plastic screw driver and popping up from the edges, it is held by clips do this slowly.
then remove the door handle cover, yes there is a cover on the handle, and just remove it by using the same screwdriver and popping open the front facing cover.
then u see 3 screws, remove those
then the panel with the seat buttons easily comes off
then you can see the area where this door light is and u can use twesers and a flat thin screwdriver to push it back in.
everything removes easily without any force at all so make sure u dont use much force.
its all pop on parts.
Old May 19, 2004 | 01:17 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Try www.startekinfo.com
Looks like you figured it out.
But for future reference, there are training CDs for sale at this MB tech website (or on a link that you can find from this website to mercedestechstore.com)
There is a CD for the W220 that you can buy for US$95.
You will see that the free taste example they show includes a short video on how to remove the driver's door panel.
