fuel gauge
Old May 22, 2004 | 02:57 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Unhappy fuel gauge
anyone have fuel gauge problems on their S? This is our first problem in 4 years / 31k miles
when i fill up, the gauge goes to full, then as i'm driving, a few minutes later, it'll drop a little bit, about 1/2 inch down the range from full. Then it goes back up a little, but NOT full. Is this normal or something wrong with the fuel sending unit?
thanks!
Old May 22, 2004 | 08:10 PM
edison's Avatar
i have similar problem, the last 2 times i fill up gas, the needle doesnt go all the way up..
anyone else have same problem?
Old May 24, 2004 | 12:08 AM
DMI+RY's Avatar
W220
Just noticed that the fuel guage does not goes all the way to full (about 6-8 millimeters away) when filling up a gas tank (last 2 fill ups).
Weird...
Old May 25, 2004 | 03:43 PM
edison's Avatar
have u guys bring it back to the dealer to have them check it out?
Old May 25, 2004 | 03:52 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
i will mention it when i go in for service soon. It only failed on me once then popped back up when i hit a bump, since then, it registers gas and hasn't left us stranded yet with it's readings, so it's not a *real* emergency right now.
i'll report back when i have the dealer look at it.
Old May 26, 2004 | 03:34 AM
hongalan's Avatar
2002 S500
My wife's ML320 had a similar problem. When she filled it up completely, the needle would not go all the way up (maybe 7/8 level). We took it to the dealer and they took care of the problem. It hasn't reoccurred in about three years.
Old May 26, 2004 | 04:10 AM
flipflap's Avatar
ML320 164
My 240d had this problem =) Its a wagon so the tank is pretty easy to get to. I took out the fuel level measurer (it works like a voltage divider for those of you who know your way around electronics, for example half tank = 13.7v / 2 = 6.85v out) I think it works the same way on the s-class. It had a lot of hairs and stuff on it, I just sprayed it with water and then with carosin and put it back in. Works perfect now
Old Jun 1, 2004 | 11:59 AM
jahummer's Avatar
s430
Just filled up this morning and for the first time ever I have the same problem Says there is only 3/4 of a tank but tank if full.
I'll talk to the dealer about it.
Old Jun 9, 2004 | 09:08 AM
jahummer's Avatar
s430
Dealer says defective fuel sending unit. Replaced under warrranty.
Old Jul 6, 2019 | 08:14 PM
Jason Killion's Avatar
2000 S500
Fuel gauge inaccuracies
Normally, if your fuel gage reads near empty, with a full tank, it is your fuel level sending unit. If it reads between full and 3/4 when near empty, it's your gauge cluster which may need reprogramming and/or repair. I have this issue with my 2000 S500, and after replacing the sending unit, I still have the same issue.
