dash vents not working
Old 01-17-2019, 07:01 PM
dgc3's Avatar
s430
Question dash vents not working
Only the outside dash vents deliver air on my 2000 s430. The central vent and the floor vents cannot be activated by rotating the control dials for directing air to upper or lower vents. The recirc control or the carbon filter control are not working. I pulled the glove box to gain access to the carbon filter (which I replaced), and confirmed that the vent does not change position when activating the carbon or recirc controls. I have done the recommended resetting steps (hold recirc and carbon controls until light stops flashing, press and release auto buttons, restart car), with no success.
I suspect failure in climate control unit. Before I buy another, can anyone recommend how to test the existing unit? Or other test that might be appropriate.
Sincerely,
DGC3
Old 01-19-2019, 11:19 AM
Plutoe's Avatar
Received 1,028 Likes on 956 Posts
1999 E300TD
you do the AC flap test-----the instructions for accomplishing the test are all over the internet
Old 01-20-2019, 11:22 AM
dgc3's Avatar
s430
Thanks,
Did flap test. All flaps indicate 0 to 100% function, however no air is directed to floor area (left and right). Typically actuator motors are inexpensive, however installation can be difficult. Scanned the site/internet for actuator locations and see that there are 3 actuators (top, central, rear vents). Can't tell where floor actuator is located. Anyone know whether access should be from driver's or passenger's floor area?
Regards,
DGC
Old 01-20-2019, 02:23 PM
Plutoe's Avatar
1999 E300TD
You can try, or do it correctly by removing the dash.
Quick Reply: dash vents not working
