2002 mercedes s430 fuel gauge not reading
Old Jan 27, 2019 | 09:52 PM
Bubba322's Avatar
Mercedes s430
I have a 2002 mercedes s430 ive been fixing up. The fuel level unit in gas tank was only reading from fuel to 3/4. Then the tank would be empty. So I change the fuel leveling unit, now its reading empty on the gauge. Also fuel pump and filter where changed. Any help would be appreciated.
Thank you.
Old Jan 28, 2019 | 09:11 AM
Bubba322's Avatar
Mercedes s430
Put a new fuel level sensor in tank now its reading empty And the fuel light is not on when its on empty.
Old Jan 28, 2019 | 12:27 PM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Something may be blockig the mechanical parts of the level sensor assembly, happens quite often when the parts are swapped
Old Jan 30, 2019 | 05:37 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
You need to check the coding in the rear Sam if it’s coded for the wrong model year you will get the symptoms you described
