Door module issue.
Old Feb 25, 2019 | 06:35 PM
Mooneyes's Avatar
1999 w220 S500L.
Door module issue.
I have a w220 s500l. My passenger front door controls don't work. I can't open window from passengers door nor drivers controls. Can't move passenger seat using the door controls but can adjust the seat using the rear passengers controls. The mirror works fine. I recently had 2 replace the drivers door control module as nothing worked. That fixed everything apart from passengers seat and window problem. Will this likely be due 2 a faulty passengers door module???
Old Feb 25, 2019 | 08:26 PM
Mooneyes's Avatar
1999 w220 S500L.
I may aswell just buy a module & find out. Got a couple of things to check but if I'm honest I hate electrics!!! I'm a panel beater/fabricater/painter. Lol.
Old May 17, 2020 | 05:51 PM
niralon77's Avatar
2007 clk350
Bad module
Does anyone knows if a door module needs to be programmed, or can I install a replacement and everything will work as it should with out going anything???
Old May 18, 2020 | 12:51 AM
tusabes's Avatar
Mercedes
as long as you get the proper one it will plug and play with no programming
