Hydraulic Trunk Motor problems
Old Jun 3, 2019 | 09:21 AM
Zindago's Avatar
S 320
Good day
I need help. I drive a W220 and the hydraulic pipes that go from the pump to the cylinder has gone through. I cut the piece out that has worn through. Now I need to know if there is a way of joining the two open ends again. I have tried everything but pressure is so high that it just keeps pushing the joints out.
Please assist as I would like to try and mend this and avoid buying a new unit
Many Thanks
Old Jun 3, 2019 | 06:31 PM
Jason Killion's Avatar
2000 S500
Solution.
There is. You can pick up some compression fittings at almost any hardware store. I use them all the time at work on air, fuel and brake lines all the time. They are very cheap, and easy to work with/install. If you've never done them before, then YouTube will be your best friend.
Old Jun 4, 2019 | 03:06 AM
Zindago's Avatar
S 320
Many THanks Jason
I am going to try this
Cheers cheers
