A/C malfunction
I just encountetred a maldunction with my a/c. The control appears as normal but there is no actual fan or air blowing. I checked the fuse and its good. What could be the cause?
The fan does turn and so do all the pulleys. However, I'm not totally sure which is the a/c compressor. No air blows at all...it totally stopped blowing. I tried a few times and it doesn't appear to be intermittent.
The HVAC blower lives above the right front passenger's feet inside the dash. Google "removing w220 blower" to get more info.
How did you find which fuse controls the blower, and which did you test?
Failure of the electronic speed regulator (which is mounted on the blower) is probably the most common problem.
AAHHHHH ok....I replaced one in our CLK430....
the fuse that I checked was F33 ( I believe)...I have to look at the diagram again.
