That pesky windshield washer tank leak
I added water to my tank, and took out the passenger headlight. I had no instructions for taking out the headlight, but there's a few 10mm bolts and I think three electrical cable connections. It's not rocket science.
A connector on a pump right in front of the windshield washer tank had blue residue on it, so I strongly suspected it to be the source of the leak. It was. I took the connector off the pump and water pours out of the pump's hose nipple:
But with the hose connector on the pump and operating the washers, high-pressure washer fluid (water at the moment) sprays out of a microscopic crack in the L-shaped plastic hose connector that slips over the pump's hose nipple [red arrow indicates location of microscopic crack right at the L of the connector]:
[EDIT] and then I pushed off that heatshrink cap on the end which shows the wiring harness goes inside that little hose. I don't know what it does, maybe it's a valve or something:
So is this a part I'm going to need from a dealer? And if so, do we know what it's called?
Any tips from anyone who has done this before would be great.
It costs roughly $120 give or take $15 from online sources.
It doesn't leak and it works fine. I'm not going to buy the $110 part.
I'm calling this one fixed.
I thought initially the crack was where the connector bends in the L-shape, but it was actually in the barrel that connects to the hose nipple. A short piece if 5/16" tubing was all that it took!
I am using W220 2001 from last 6 years with no issues at all.
now at once i am facing this issue. When ever i go through any jump or any broken road with just 20KM/Hr speed or above the power fluctuates like everything goes off and comes back immediately.
does anyone know about this issue.
Please do let me know. waiting for reply
