Chasing a low pressure ABC fault
Old Oct 2, 2019 | 12:31 PM
Fried Chicken's Avatar
2005 S500 Designo
Originally Posted by tantumaude
I've been advised to try changing the ABC control module. Anyone know if I can use any control module (from another model CL/SL/S) or does it have to be from an S600?
It may require a DAS
Old Oct 2, 2019 | 03:04 PM
tantumaude's Avatar
S211 E55, R129 SL500 + others
Thanks to both. I ordered a used module from a 2002 CL500 and a DAS system. Will report when they arrive.
Old Oct 2, 2019 | 06:05 PM
2005 S500 Designo
Where did you get a DAS system from?
Please don’t take my advice for anything more than just rambling, I may be completely wrong, a DAS system might not be necessary, or you might do damage to your car by installing the wrong control module.
That being said a DAS system is always handy to have when owning these cars.
Old Oct 2, 2019 | 06:23 PM
tantumaude's Avatar
Yes, it's about time I got one. Ordered from China...so it may or may not work.
Old Oct 2, 2019 | 10:07 PM
wallyp's Avatar
2003 S500 2007 GL450
I've bought three from China - all worked fine. The hardware, especially the cables, looked like aerospace quality. (I had a long career in aircraft manufacturing.)
That being said, there is a pretty steep learning curve on the system - it is a large, powerful set of software.
0
Old Oct 3, 2019 | 01:48 AM
2005 S500 Designo
How much does one cost? I want one from china
[edit]
it doesn't have to be china, actually i'd prefer one not from china, but rather, cheap
Old Oct 3, 2019 | 09:52 AM
  #32
wallyp's Avatar
That is not a simple question - there are quite a few options. In descending order of price and ease:
- Buy a complete turnkey system from a local vendor (if you can find one).
- Buy a complete turnkey system from a Chinese vendor.
- Buy everything as a system except for the laptop. The software will be on a conventional hard drive or an SSD. Build your own laptop from eBay.
- Buy the pieces where you find them at the lowest price.
I opted for the middle choice. Bought several Dell D630 and D830 laptops, bought the fastest CPU available, maxed out the memory, new battery, etc. Bought the rest of the system from a Chinese vendor. Total cost was between $500 and $600.
A friend has a complete system like the one that I use that he wants to sell. I think that he wants about $500 for it. He just sold his S430.
This is a complex subject that has been discussed online for several years. There are numerous threads on the Mercedes forums...
Old Oct 7, 2019 | 09:16 PM
  #33
tantumaude's Avatar
I ordered a multiplexer and HDD with the software. I have a couple of old laptops that will hopefully work (with serial ports). Still hasn't shipped though. I paid 260USD shipped.
Wait and see...in the meantime I tried replacing both ABC fuses on the off-chance something might be awry, but no luck. Still very stiff.
Old Oct 18, 2019 | 04:12 PM
  #34
tantumaude's Avatar
Got the DAS today. Tried every possible test and actuation, the car passed everything perfectly with no faults and aggressive bouncing. The replacement ABC module should arrive later this week.
Old Feb 23, 2023 | 12:11 PM
  #35
sushistrip's Avatar
2015 S550 4MATIC
Was this ever solved, I'm having similar symptoms.
Old Feb 23, 2023 | 06:40 PM
  #36
2005 S500 Designo
Where did you get your DAS system from?
Old Feb 24, 2023 | 10:48 AM
  #37
tantumaude's Avatar
This was nearly 4 years ago. I never fully resolved it, sold the car instead when I lost most of my work during covid.
DAS was ordered off Aliexpress. Still works great.
Old Feb 25, 2023 | 06:59 PM
  #38
Kebowers47's Avatar
001 s600, 94 sl600
The un-solvable issue you had with the ABC system is exactly why many Owners gave up on ABC. I gave up after I did a good evaluation of flex hose replacement -cost forecast, me doing the labor, hydraulic shop hose replacement, and reluctantly switched to strut-overs.
The certainty of future strut failures and the unavailability of replacements drove me out.
Old Mar 20, 2023 | 11:39 PM
  #39
joemolina1991's Avatar
mercedes c55
I solved part of the problem: the PSI supply fault was caused by the pump which, every 30 seconds or so, would momentarily drop pressure to about 40 bar (lasting about 1/2 second), before rising again. This happened too fast to register on a digital gauge, but was detected by an analogue gauge we hooked up to the pressure sensor.
Changed the pump again, that problem is now gone. However, the harsh ride remains, as does the "ABC control lock on" message on the Icarsoft. No fault codes whatsoever anymore though.
Any thoughts appreciated.
Curious what pump did you use that solved part of the problem? I’m looking. For a good ABC pump supplier.
Old Mar 21, 2023 | 09:11 PM
  #40
2005 S500 Designo
It's likely not the pump but the solenoid right on top of the pump. You can remove it and actuate it manually with +/-5V.
Old Mar 22, 2023 | 05:01 PM
  #41
Kebowers47's Avatar
001 s600, 94 sl600
You need to bleed the air from everywhere in the system. If the ABC is locked off, it must be reset using the WIS (Mercedes) software/hardware system. It will NOT show the lock-out on any other scan tool. Lots of owners give up when this 'stumped them'. When you encounter a 'what is it' situation, no substitute for a good system diagnosis from a skilled tech FAMILIAR with rhe MBZ software diagnosis system, This is not a system to 'learn on.'
Old Mar 30, 2023 | 10:16 PM
  #42
Kebowers47's Avatar
001 s600, 94 sl600
The single biggest problem with older ABC systems is the certain failure of all the flex hoses. Mercedes rubber jacket fails and allows moisture to rust the plain steel wire reinforcement. I regret giving up and installing strut-overs. The ride is very good. The certainty of strut failure eventually and the non-availability of rebuilt or new replacements is what convinced me to switch.
