Chasing a low pressure ABC fault
One month ago, after parking, noticed a pool of fluid under my front left wheel area. Maybe about 1L of fluid. Seems it flowed out of the reservoir vent hole. Got red ABC warning.
Towed car to indy. Pump was apparently putting out 0 pressure.
Changed pump (rebuilt), bled system, etc. Passed rodeo no problem. Took the car home, it drove very poorly. Felt 'floaty' on road undulations, and very harsh on bumps and dips.
I get the white 'visit workshop' message when I hit the first serious bump of any drive. Turning the car off and on resets it. The code indicates "PSI pressure supply too low". (1526-016)
Level adjustment works perfectly. No sagging, no leaking that I can tell. System passes rodeos no problem, and pump puts out 184+ bar of pressure at idle.
Changed front and rear accumulators as well last week, drives a bit better but still similar issues with harshness on bumps and some floatiness. The white error comes on during most drives, sometimes while passing over bumps, sometimes not. It can come on 2 minutes in, or 20 minutes in, or never.
Not sure what to attack next, any ideas?
DAS includes guided diagnostic tests for virtually every part of the ABC suspension system, and should quickly and easily identify your problem.
I'm personally thinking wither one of the two remaining accumulators (which shouldn't really be affecting the ride that much I'd imagine); that the replacement pump isn't putting out enough pressure; or that there somehow is a bubble in the system somewhere.
And, YES, a bad accumulator DEFINITELY adversely affects the ride quality. The flat accumulator can no longer absorb the many road surface irregularities.
As I said, an accumulator that is supposed to store high pressure oil to feed to the strut when needed--cannot do that if it has lost its nitrogen charge--like a deflated balloon. When the System calls for HP oil to add to a a strut, and it is not there, the system pressure instantly drops to that of the strut and triggers a Low Pressure warning. The pump eventually catches up (in a few seconds) but that might be 300' down the road. A flat 'hp return' accumulator is the opposite--it can not receive and store HP Oil as a 'reserve supply' as it is completely filled with oil when the nitrogen pre-charge is gone.
I used to be 'the guy' supporting the Infiniti Q45a the Active Suspension worldwide, manufacturing replacement accumulators and rebuilding other parts for them.
I also manufactured replacement accumulators for the height control and suspension system of the Lexus LX 470 and 570 luxo SUV's and provided lots of technical advice and support. Lexus techs never got training on the system and 'soccer Moms' complaining of a harsh ride usually got hit with $7000 or more as Dealers simply 'threw new parts everywhere.
I also support the Porsche 959 Super-cars and their full active suspension and the MBZ '100 series' vehicles such as the 450 6.9 ones and other cars with hydro-dynamic suspensions. Citroen's are well sorted out and Citroen Techs well trained in Europe and accumulators are inexpensive for them.
The ABC system licenses the patents Nissan holds. The Nissan system is superior to the ABC in many ways, including a very high capacity pump (17 L/min) that never failed.
"I'm personally thinking wither one of the two remaining accumulators (which shouldn't really be affecting the ride that much I'd imagine)..."
"Given that the primary/supply accumulators were replaced, though, would a failed return accumulator alone..."
How many accumulators - and which ones - have you changed? Are you changing the parts, or is a tech telling you what he has done?
We have NOT changed the other two (parts 2203200415 and 2203270215)
Stumped again.
As for the flow restriction, that seems like a very possible thing as well. I'll try to do a more thorough inspection this week to see if we can detect anything of that sort. It seems all four corners of the car are equally affected, so I'll pay particular attention to the main lines by the pump. Thanks!
With no performance symptoms (other than alarm caused) is the 'low pressure' real or an unusual pressure transient or 'overly sensitive' pressure detection system. It seems the car DOES have good pressure delivery everywhere but the 'low pressure' switch function. Is there any way to easily add a mechanical gauge? Or just replace the 'suspect' low pressure switch?
Good Hunting!
I'm debating whether to change the return accumulator (due to the initial fluid spill on the first day of the problem), and possiblty pulsation dampener at the same time.
A MB tech at the dealer (I was there for unrelated business) suggested the pressure supply valve, but everything I read leads me to believe a failure there would have given more codes.
Started to get the fault more and more often. Ran a couple of rodeos, and the car stopped many times with a corner down, running about 90 bar.
I'm thinking either the pump is bad, or the pressure supply valve.
To recap--the car drives as if it had blown shocks: it floats around a bit on road undulations, but every bump is extremely harsh. I intermittently get a white ABC warning message indicating "malfunction in pressure supply" (1526-16), which doesn't affect the ride. Pump puts out 185-189 bar, passes rodeos, no leaks, can raise car quickly and evenly.
I do get a message on my icarsoft scanner saying that the control lock is on, whatever that means. I'll see if I can find anything on that.
Changed the pump again, that problem is now gone. However, the harsh ride remains, as does the "ABC control lock on" message on the Icarsoft. No fault codes whatsoever anymore though.
Any thoughts appreciated.
Chrysler Corp learned many years ago working with Motorola and used a common (identical) 'module' for every function but different computer instructions (PROMS) easily adapted(programed) for purpose.. Toyota has only two (2) radiator caps/filler necks GM had hundreds of different and incompatible ones.
