A/C error KLA A 1257
This is For The 2004 S430 4Matic
So my compressor went out, I replaced it, added proper amount of oil, new electrical connector to the compressor because the original one broke apart when I took it off and replaced the Dryer.
I put a vacuum on it and it went down to where it should. I closed off the manifold gauge and it kept the vacuum for an hour. I continued to pull the vacuum after that for an hour. All was good it held great.
So now I go to charge it and the AC light wont go off. I go to Diagnosis and get that error. I erase it and the light goes off for about 1 or so minutes and then goes on. In that time the compressor never sucks in any refrigerant and the error gets tripped again.
So now what?
It held the vacuum like it should so no leaks but how do I clear the code and get it to suck in the refrigerant?
If lo pressure the system gets shut down for protection.
Once recharged (You can do that by introducing liquid into the high pressure line without the engine running (one can)), you need to reset the system to clear the shut down fault.
Then run it and charge the rest (all by quantity, not pressure).
Good luck!
I can only get the error to go out for a minute or two and the compressor refuses to turn on.
Then, you need to get into the center display and go into the HACV menu and reset the system.
after that, you can charge the rest with engine running thru the LO pressure side.
Read, read and know what you are doing!
Good luck!
The CORRECT charging procedure is to vacuum out the system to less than 50 microns, shut off the vacuum pump and let things sit for an hour to check for any leaks. Then connect refrigerant canto the LOW side and Hi side, adding up to the 'full charge' weight. Then start the car etc.
NEVER connect a refrigerant can to the Hi side with the compressor running---the compressor discharge pressure can explode the can.
As I said I connected the can to the Low side but the compressor would not suck anything in because of the error. I was able to clear that error only temporarily which was not nearly long enough to get the compressor to suck anything in.
I wanted to know if anyone had this happen where the car is saying it will not turn the compressor on because of the low refrigerant. Obviously it is low it is empty. The car will not accept any refrigerant.
How do I get the car to keep the error cleared and let the compressor suck in the can of refrigerant?
