02 s500 ecu eis shifter Any Input Is Welcome
Old Jul 29, 2019 | 01:21 AM
S500915's Avatar
02 s500
I have a 02 s500 which started having trouble ignition switch key would get stuck then after 5-45 minutes the key would randomly work. Sometimes the key would turn but nothing would happen. I have decided to buy a ecu, eis, key fob, and a shifter from a donor car from eBay ecu same matching numbers my question is will this parts work for me, am very mechanically inclined n have the scanner to rewrite the vin to the ecu .Will this work n can someone please verify am doing this right Thanks Everyone
Old Jul 29, 2019 | 07:13 AM
speedlimit's Avatar
Administrator Emeritus
Hi and welcome!
Thank you for posting your question in the W220 forum! Good luck!
Bob
Old Jul 29, 2019 | 10:08 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W220 forum...
Old Sep 8, 2019 | 02:55 PM
johnksss's Avatar
2011 S550 / 2001 S430 - RIP
They should work as is if you install them all, but if you start tampering with them, you may render the car in operable. (This is only if you have no clue about eeprom removal and hex editing. Also the right tools for the job)
You can't make VIN number changes once they are married to each other with standard tools like SDS.
