2005 S500 Loud Humming
Old Aug 9, 2019 | 06:18 PM
TurkinaBenz's Avatar
2005 Mercedes S500
Hi all - noobie here. Bought a 2005 S500 for my father with 70k miles for $8000. The car was excellent and we loved it for the first two weeks.
A few days ago, we noticed a loud humming sound when driving and slowed down or at stop. As of today, the noise has gotten louder and we also noticed there is now sluggish acceleration.
No warning lights—just the noise. When the noise is at its loudest, turning the AC off seems to lessen it. It is so loud that we can hear it in the car with the doors and windows up.
Any thoughts would be appreciated. No idea where to start!
Old Aug 9, 2019 | 10:25 PM
wallyp's Avatar
2003 S500 2007 GL450
First effort should be to locate the source of the noise. One way to do that is to get a piece of 1/4", 5/16", or 3/8" (convert if you are metric) rubber or plastic tubing about four feet long. With the engine running and hood open, place one end of the tubing in your best ear. Use the other end of the tubing as a probe to locate the source of the noise. Stay well out of moving or hot parts!
Simply having the open end of the tube near the noise source should give a noticeable change or increase in the noise level thru the tube. Touching (safe, non-moving) parts with the open end can also help to determine the source. Check around the AC compressor, which is located down low on the left side of the engine. (Remember that left/right on a vehicle is always defined from the viewpoint of the seated driver, so the left side of the engine will be on your rights as you stand in front of the car.) Another common noise source is the belt and pulleys, especially the idler pulley.
Determining what affects the noise is also helpful. Does the noise change with engine speed, or with road speed, or neither?
Is the noise coming from the engine compartment? Or from the dash area? Or the vents? Does the noise change with blower speed?
None of us can give you a magic answer - only you are there to listen and determine the source...
Old Aug 11, 2019 | 12:35 AM
tusabes's Avatar
Mercedes
Just take it to a mechanic , clearly you aren’t capable of repair or diagnosis yourself
Old Aug 11, 2019 | 02:38 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
is that car has ABC, look at the hydraulic system for damper faults.
Old Aug 11, 2019 | 03:32 PM
Fried Chicken's Avatar
2005 S500 Designo
If it has the ABC suspension it’s the pulsation damper.
Old Aug 12, 2019 | 10:56 PM
Kloxe55's Avatar
s 500
I have a 2004 S500 and when I heard a humming noise it was the bearings in the hub assembly had gone bad. I replaced the hub and no more noise.
