Replacing Head unit of S500 03 with android
i need help in choosing the suitable unit for replacing my original unit (photos attached bellow) with android one,
my car 2003 s500 japan model, comes with fiber optic system, Bose,
is it D2B or MOST?
I need to know if it is possible to be upgraded,
the chinese models recommending to purchase cable to connect from unit to rear amp, while they have adapter for fiber optic but they are not sure if work!
the other question some models had DSP system
is it necessary or useful if the fiber optic adapter functioning?
And if connecting the suggested cable with DSP function my speakers will work fine?
I hope i get some help,
Optical fiber decoder/canbus for Mercedes Benz ML/R Series; For Porsche Cayenne Series
https://s.click.aliexpress.com/e/sBztTTS0
this unit with DSP
IPS DSP 8 Core 2Din Android 9.0 Car Radio Stereo GPS Navigation For Mercedes-Benz S-Class W220 CL-Class W215 Bluetooth WIFI USB
https://s.click.aliexpress.com/e/kQeqGD6g
but this looks better while it dose not have DSP system
Seicane Car GPS multimeida player For 1998-2005 Mercedes Benz S Class W220
https://s.click.aliexpress.com/e/kGB6lBqu
Seicane Car Optical Fiber Decoder Most Box for 2002-2012 MercedesBenz E-Class
https://s.click.aliexpress.com/e/F7jTutdq
Best regards,
SAYED,
Since August of last year, the 2000 S500 (the wife's car) has had the Erisin ES3782S Android system in it. This is a four-core, 2GB DRAM unit that, with all accessories, cost about US $550, shipped. So far, it's proved to be a fine performer. Today, I would suggest the Erisin ES7892S, with its eight cores and 4GB DRAM. That's the one that the S600 is going to get once I get something else fixed on it. Total with all necessary accessories was about US $530, including DHL shipping.
BTW, yes, you do completely bypass all the D2B fiber-optic stuff when you do this. The way to do that is with Erisin's "LMBENZ-6m" copper cable that goes from the head unit to the trunk. Completely replaces the fiber-optic run with copper wiring. All speakers get hooked up to this LMBENZ-6m cable, and the door speakers are powered directly by the head unit's built-in 45W/channel amplifier. I installed an extra amp, an Alpine 300W model, for the 10" woofer in the back to round out the bass response. This works very well.
Note that the factory Bose speakers do require the (in)famous "Bose equalization", known by any and all owners of, say, Bose 901's. Same applies here. In this case, the factory head unit has the Bose equalization curve built-in. The new Android head unit will have the standard flat curve. Therefore, the treble can seem a bit flat. My solution was to replace the 6.5" speakers with some aftermarket co-axial ones (Phoenix Gold makes a nice one, the SX65CX). This brightened up the sound considerably.
Yep, agree with @cowboyt a lot have done this conversion, the trick is in ditching the Bose, don't be tempted to use the F/O Converters on Post Facey's get the 6m Cable, and on both pre and post F/L remove Amp and Hard Wire the Speakers.
If like me you have a non Bose Car then it's even easier, as the Speakers all work fine, and Speaker Connections are right on the back of the old COMAND H/U
The woofer takes a + from one Rear channel and it's - from the other Rear channel, same for centre dash except use + and - from the Front 2 Channels, I'll see if I can find the diagram / wire colours, or perhaps Cowboyt has them he could post up.
When wired correctly these are awesome, I got one in my R170 SLK too
HTH, Cheers Dave
help would be greatly appreciated. Thanks
finally i decide to purchased unit,
seller promised for working fine with extension cable, but unlucky i couldn’t be able to connect or find where to connect the extension cable, amplifier connector totally different from the supplier items
if any body have ideas,
last one is the target connector but i couldn’t find similar
