Airmatic Compressor Hoses
Old Sep 1, 2019 | 07:48 PM
ACCUbenz's Avatar
W220 S430 2006
I have a S430 2006 with Airmatic Suspension message. my problem is the two hoses between the compressor filter and the compressor are cracking. I cant seem to find the intake hose that goes from the filter to the compressor nor the other side of the filter cup that holds it (the filter) and goes into the main air canister. Any suggestions?
Old Sep 3, 2019 | 06:23 PM
wallyp's Avatar
2003 S500 2007 GL450
I replaced both hoses on my 2003 S430 with standard fuel hose of the correct diameter. Works fine. You can also replace the "air filter" with a standard in-line fuel filter, installed in the reverse direction - that is, the incoming air flows from the fuel outlet to the fuel inlet as shown by the arrow or other marking on the fuel filter.
