Airmatic leveling issue
Old Sep 3, 2019 | 06:52 PM
S500 W220's Avatar
S500
Angry Airmatic leveling issue
Hello people. I have a 2006 W220 S500 with a airmatic issue. The passenger side rear is about .75-1 inch to low. The valve block, airmatic computers, shocks, everything replaced and tested but the problem still persists. Zero airmatic codes. All shocks adjust as they should with STAR. I have no clue what it could be anymore. I took it to Mercedes Benz to be repaired, paid $900 and still have the issue. The car all the sudden started leaning in that corner one day. Shocks replaced. No leaking. Any help will be greatly appreciated.
Old Sep 3, 2019 | 08:11 PM
cowboyt's Avatar
Mercedes-Benz S430, S500, S600, and E320 CDI
What happens when you raise the level of the car with the dash button? Anything?
Old Sep 3, 2019 | 08:24 PM
S500 W220's Avatar
S500
Everything raises fine. That side goes up the same as all the others but is still around .75-1 inch down from the others.
Old Sep 4, 2019 | 10:55 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Are you getting plausible, changing voltage readings and voltage range from both level sensors when moving car up and down by star?
Old Sep 5, 2019 | 09:21 AM
Kebowers47's Avatar
001 s600, 94 sl600
try resetting the right rear height sensor linkage. May have gotten 'adjusted' by debris.
Old Sep 5, 2019 | 09:36 AM
wallyp's Avatar
2003 S500 2007 GL450
There is only one rear height sensor, connected between the center of the anti-sway bar and the chassis.
There are position sensors inside each strut, adjustable only thru DAS.
