S500 Break light issue
Hello everyone,
Im Johnny and Im from the Caribbean. I imported a 2001 S500 from the USA with an issue I can't seem to solve. Here it is; As soon as I start the car the break lights come on and it never goes out until I turn the car off. I checked everything I know but the issue still persist.
I wish I can get some help here.
Thanks in advance
Johnny
Thanks in advance
Johnny
Replace the brake light switch behind the brake pedal. Relatively cheap and 80-90% chance to solve the problem. But watch out to pull the (white??) pin of the new switch as far as it goes, so the new switch calibrates itself to the pedal travel
If it's not the switch, then the problem is likely in your rear SAM.
Tucked under the passenger side rear seat is a Signal Acquisition Module. If water gets in there (which is not uncommon) it can cause corrosion, shorts, and failures of that module, which affects quite a few systems, including brake lights.
Change the switch, as suggested, but make certain that it's clean and dry under that right rear seat as well as under the front passenger footwell carpet...
Thanks for ur reply Vinflouen. Did u have an issue with the brake lights? also, what is it that they sell on amazon that I can get one side of? if its the lights themselves< I doubt they r bad cuz I switched those also with another s class that I have.
Hello everyone,
Thanks in advance
Johnny
Thanks in advance
Johnny
if it’s just the running lights this can be a daytime running lights setting
Any info on the possibility of the shifter being part of this problem with the brake light. I had someone scan the car and he told me the problem is the shifter. The thing about that is that the shifter is coded and that’s gonna cost about $1300. Don’t wonna spend that then find out it’s not the cause.
