2005 S500
Old Jan 13, 2020 | 05:24 PM
Chris White's Avatar
S500
2005 S500
2005 S500 having issues with door locks to work. I have checked all fuses and hear a click from the trunk likes suppose to work. What might be the issue with this. Also, battery was reset
Old Jan 13, 2020 | 06:01 PM
tusabes's Avatar
Mercedes
did you pull the 20amp fuse under rear passenger seat ? That’s what resets it
Old Jan 13, 2020 | 06:06 PM
S500
We have looked at f62 but coming down to it we found more info on it than expected.
Reading the car vin on the ecm is dufferent than the one on the door jam.
also we have tried all ecm and fob resets but still nothing is happening.
Where we are at that the pse pump might be bad. The fob and dash buttons work but no responce to the locks. We hear a click at the pse but no air movement that we can tell
Old Jan 13, 2020 | 10:10 PM
tusabes's Avatar
Mercedes
The pse pump will shut itself off as a protective measure if it has sensed a leak . That’s why you must reset it using the fuse pulling method .
