Trying to sort airmatic
it's a106,000mi west coast car,.s500
i have fixed the leaking fitting ontop of the pass strut,. I have a very small leak at valve block which i will sort out soon.
when i drive the car in a spirited fashion around tight twisties,.the airmatic releases air in quick exhaust bursts til the message in the dash comes on saying airmatic too low. Is there supposed to be a pressure release delay of some sort to avoid this?
I Did a quick hook turn yesterday on a wet road to go in opposite direction and front susp deflated,.
I'd appreciate some help,.
thanks
While it is not a perfect answer, many DIY owners have bought Airmatic struts rebuilt by Arnott, a Florida company. The struts are between $300 and $400 exchange, and come with a lifetime warranty. Arnott recently stopped supplying struts directly to owners, selling thru selected auto parts chains, such as Autozone. I have bought several Arnott rebuilt struts, and have had two fail. Both were promptly exchanged at no cost, but I had to do the R&R.
Few owners recommend using the cheap no-name replacement struts available online, but a couple of folks have gotten a couple of years of service out of them so far.
This will give you some basic knowledge on the system. https://w220.ee/Airmatic
car has 1 new strut on pass side,. So i would hazhard a guess that the drivers side is NFG
what you have told me makes perfect sense too as when i stuff it hard out of the hole it lifts up and dumps air,.
What is a facelift model,.?
suspension will not pump up,.
going to have to beg the neighbors shop and see what i can do,. might have to break out the inner tube repair for my kids bicycle,. lol.
on another note i did buy some nice 17x8.5 amg 5 spokes,. i just need some amg bumpers abd trunk lid spoiler,.
Moisture in the system is often caused by a failed rubber fitting or hose between the compressor and the system air filter/intake tube. This lets in enough moisture to saturate the dessicant located in the compressor's inlet/outlet tract.
can the compressor be disassembled to dry the dessicant,.? i will try and order a new air filter for it,. and i looked at a site with a scots lad that makes replacement piston rings for the compressor,.?
thanks for your help,.
here is a detailed step by step on replacing desiccant in the pump
https://www.benzworld.org/threads/ai...ccant.2411265/
You can disassemble the compressor and change or dry the dessicant - bulk dessicant is readily and cheaply available on-line.
That is one of the many little projects that I need to take care of on the 2003 S500 that I recently bought - the right rear strut drops after a below-freezing night. Pull the compressor, check the inlet tract rubber fittings and lines, replace the filter (which is just an in-line fuel filter), replace the dessicant, replace the piston ring, see if the valve block will come apart, etc., etc. Hopefully, it will be a casual one-day job. Biggest problem is likely to be that I might have to wait for some parts, such as the rubber fitting on the compressor inlet.
In the past the car has pancaked the front struts,. but never all four,..
will the air springs be hurt now<.?
like all newbbes at this point i,m wondering about a coil conversion and do away with the airmatic if its not reliable in cold temperatures,.
I would propose to lift the car, with a "low rider" car jack, before changing the compressor and trying to lift the car again. Just to unload the pressure to the air bladders in the struts. The lifting points would be the differential in the back and the center car jack point on the center of the front axle.
while it was sitting in the driveway on uneven ground with the motor shut off key out, we watched the front end sink slightly then raise up,. it did this 3-4 times over 10 mins,. then it has dropped the front end down again,. I will definitely check the valve block when i get it onto a hoist,.i would think it drains the reservoir for either a leaky strut or valve block, which is yet to be determined,. but i also have my suspicions on the pass side ride height sensor,. If the car is parked with the wheels turned to the left, car maintains its height over night,.
to be continued,..
removed compressor and valve block,.
disassembled comp in the kitchen and water ran out of every orifice,. That explains the bad cold weather performance. The desiccant looked like clumped beach sand,. So i put i
t in the oven at 175f for couple of hours
dried everything off,. Air filter rubber hose was cracked at one bend,. So unfiltered air was getting in.
everything is reassembled on the compressor will put it back together tomorrow. I think if the compressor could draw its air from a better spot it would be better i will soak the air filter with methyl hydrate and the fumes should help things along,.
The Airmatic system should only pull in enough air to replace that which it dumps when you and you passengers get out of the car, or when you unload the luggage and liquor from the trunk. The replacement air should be dried as it goes in, and the dumped dry air helps keep the dessicant functional. It will take a long time to get all of the moisture out of your system, but it should gradually happen.
Good job!
Put everything back together yesterday and car rose up nicely,. Compressor now releases a little air right at the end of its cycle, like the air dryer does on the big truck
Why would i need to buy new Desiccant?
Wally you are right about the intake hose,. If i open up the first bend it definitely is cracked through,. So i need to source s new one
The car still has its filter upper condom,. It is in good shape,. The filter lets air thru easily in both directions, no idea if it actually filters air or not,.😁
Only thing thats nagging on my mind is if i got the 2 rear strut hoses in the right outlets,. My son was helping me,. And he cut all the hoses off before i had them mapped,. Colours are worn off,. I used 5" of new line for each port except the compressor feed line, with good quality brass push together connectors,. Trying to push old lines thru the new, port clamp nuts, was impossible so cropped the lines back to where they were straight and it all went easily. The new line and 5 connectors cost more than the valve block!!
So i'm in for about $100 cdn so far.
We'll see whats next! 🤪
Where to source the new hose without a mortgage,.?
i was so happy the car raised up ,. I counted my chickens before they hatched and off i went.!!
meanwhile back to reality. I had airlines so mixed up it was embarrassing,. So i took the airlines off the front struts and blew thru them figured those two out,.
the reservoir was easy, then made a little rigging to blow up 1 back strut and then things worked like they are supposed to!!
Iam pleased to say that so far i have been very lucky with the valve block
now i am sure the pass front strut has a leak somewhere.
thanks to everyone and their advice.
now if i could just figure out why the cruise quit after i did the ecm reset.
