ABC + Power Steering Service Questions
1. Since the systems share a pump, is there a preferred order to which one is serviced first?
2. I have 10L of fluid for the ABC service. How much additional fluid is needed for the PS service?
3. Some vendors are recommending a 2-filter approach for the ABC service. Is this the current best practice? I will be using the AGA ABC tool so if anything, the initial replacement filter would need be changed out after the flush is complete and the vehicle is driven a bit.
Appreciate any input on this.
-The AGA tool is neither compatible nor needed for earlier ABC systems.
-Cleanliness is critical. Before opening anything, I prepped the reservoir area via compressed air, a shop vac and cleaning away anything I could with a clean towel and rubbing alcohol.
-Siphoning fluid out of the reservoir is absolutely imperative as it holds a substantial amount of fluid. After drawing out the dirty fluid, I added 0.5L of clean fluid and extracted once more.
-Activating the ABC system via Xentry will make this job significantly easier.
-When refilling, the reservoir empties quickly. Have your containers open in advance and be fully focused while refilling.
-It took around 7.5L of fresh fluid being cycled for the fluid draining out to be clean. Perhaps the first step with the reservoir cut down on how much fluid is needed.
Next Steps:
-I'm going to change the filter again after ~100 miles. Especially considering the upgrade to the newer 3 micron filter, it's an inexpensive safeguard.
-Moving forward, this will be a 20-25K mile service for me.
Lubricants are CHEAP CHEAP compared to the cost of parts they protect.
Follow the current manufacturer recommendations--unless you have a definite improvement to use (like DEXRON VI over earlier version.
USE ONLY PREMIUM quality products. 'Names' are licensed to lube blenders, and not everyone does the best for customers.
Change lubricants before they "need to be changed", wear out, get dirty, get wet. Auto manufacturers change intervals ARE MUCH TO LONG. ('survive through warranty period, then crater.) You will always be much better off by changing lubes, filters, brake fluids, coolants twice as often as 'Owner Manual' intervals.
WIX makes much better filters than most everyone else.'Name Brand' [even OEM ] are not necessarily better. 'BIG' filter names are not best. RESEARCH
CLEANLINESS is VITAL for best service and component protection.
Hydraulic oils DO WEAR OUT. While they don't have combustion by-products to deal with, the ADDITIVES in them DO WEAR OUT. Anti-wear, anti-corrosion, anti-foam,friction modifiers, seal conditioners, anti-oxidation, anti-rust, etc.
they have a lifetime warranty on Everything including all oil and fluid
save your old fluid in the containers and the next time you need to order fluid , you buy it from fcpeuro and send them the old stuff for a refund
https://www.fcpeuro.com/page/lifetime-guarantee
In many cases, the cost of shipping outweighs the benefit of a replacement under the warranty. Personally, I never ship anything back. Generally head to Boston a few times a year and plan a stop to FCP on the way there to drop off items for any claims.
I still order from there anyways - their prices are not marked up because of the lifetime warranty and they also have very good service and staff. Also that lifetime warranty does indeed work as a peace of mind even though it will rarely be used.
