Ongoing windshield washer leakage issue 👎 .. and siren alarm replaced 👍
Old Jun 10, 2020 | 01:40 PM
john campbell's Avatar
E320
Took my 03 S500 to my indy today and got a new alarm mechanism installed. No more random sirens, so far so good. 🤞 Plus, I love that the newer one chirps on locking and unlocking.
I also had him install a new washer fluid tank but as soon as I pulled back into my garage (20 minutes later) the washer fluid was literally pouring out and the tank was bone dry. So now I guess I’m going to do what I should’ve done first and check out the parts from Auto Zone or O’Reilly’s and simple fixes as discussed here.
As of the tank replacement today, I now get 2 start up messages, check washer fluid level which I previously had but also check coolant level which I Did not have before. I noticed the check coolant level before leaving the Indy so he checked it and said it was fine. I made the trip home and the temp stayed within where it typically runs in the summer, 80- high 90s depending on if I’m running down the highway at 70 or sitting stopped in road construction. Had both on the wash one today.
I’ve read that low washer fluid can trigger check coolant message on some “older” vehicles. Would that be true for an 03 W220?
Is there anything I should especially be looking for or thinking about?
thanks in advance. 😄
john
2003 S500 4Matic
Old Jun 11, 2020 | 09:59 AM
E320
Well yes I will be going back and getting this worked out.....I just like to be armed with as much info myself as possible.
thanks.
Old Jun 14, 2020 | 12:27 AM
tusabes's Avatar
Mercedes
Engine coolant circulates in A tube in the washer fluid reservoir to heat the fluid
sounds like your guy didn’t install it correctly
Old Jun 14, 2020 | 10:02 AM
E320
Thanks. That’s what I sort of thought too. Will be getting it checked back out.
